The short coolant lines you mention that are behind the pipes- can you see them without taking pipes off? How many are there? Just took a closer look today, and theres coolant leaking under the car, right around the center where the water pump is. But couldn't tell if it's a hose leaking or wp. Will I be able to check this by taking only the drivers side tb cover off? Thanks again!
